change oil light - Monte Carlo Forum - Monte Carlo Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 12-12-2011, 03:26 PM
Default change oil light
It looks like during my last oil change who ever did it put 5w30 instead of 10w-30 i was wonder if this why my change oil soon light is on? I've barely went 1600 miles since oil change and light started coming on since last week.
Old 12-12-2011, 03:27 PM
5w wouldn't affect it. Whoever changed your oil probably never reset the light.
Old 12-12-2011, 04:32 PM
Quote:
x2. Mine did that a couple of times - so now I just reset the light after I have the oil changed because most shops don't think to do that.
Old 12-12-2011, 06:23 PM
well when i went there in the change oil light was on,, so i know they reset it seems strange it would come on again after 1600miles usually i get 5-6k miles before it comes on
Old 12-12-2011, 07:03 PM
DRuben's Avatar
I think its a timer and not a sensor like some high end cars. Click here and refer to 2002_Black_ss post. It works and will reset the light, did it a month ago on my car.
Old 12-12-2011, 08:53 PM
check your oil, maybe it is bad
Old 12-12-2011, 08:55 PM
BlackRainSS's Avatar
Do most people use 10w in their montes? I guess I never thought about that, I use 10w-30 in my truck but 5 in my car.
Old 12-12-2011, 10:07 PM
mine calls for 5w30!
Old 12-12-2011, 10:10 PM
I swear mine does too! I'm like 100 percent sure it does because I'm a worry wart about my car and always check into what to use before doing anything lol.
Old 12-13-2011, 02:42 AM
pretty sure all monte's take 5w30. 10w won't hurt anything, just a thicker oil. but probably not the best to use in colder weather, unless the vehicle calls for 10w.
the older generation oil lights are based off of how many times you start the vehicle, how warm the vehicle gets on every trip, RPMs on every trip, and other engine readings. that all determines when the car thinks it needs an oil change by how much abuse the engine takes.
newer generation(06 and up MCs and Impalas) use basically the same method, but give you an oil life percent. where as the older montes and impalas just turn the light on when it's time.
i personally still go by the general 3 months or 3k miles. and i probably always will too.
Reply
Thread Thread Starter Forum Replies Last Post
2 quarts of oil between every oil change? mstrmysterious63 General Monte Carlo Talk 22 09-25-2012 04:04 PM
Resetting Change Oil light without factory radio lu9103 Monte Carlo Repair Help 10 02-26-2012 09:11 PM
Who uses the oil monitoring system to change their oil by? 70monte1 Engine/Transmission/Performance Adders 25 01-19-2010 10:04 PM
Change oil light PackedFunk Monte Carlo Repair Help 3 09-23-2008 07:16 AM
change oil soon light big green dog Monte Carlo Repair Help 2 04-08-2006 10:52 PM
Tags
06, 1999, 2000, 2006, 98, carlo, change, chevy, light, message, monte, mote, oil, reset, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
