CEL- code P0420
Old 06-28-2006, 01:05 PM
01whitess's Avatar
Default CEL- code P0420
Recently tripped a CEL. Autozone pulled up code P0420. I replaced the 02 sensor after the 'cat', which was recommended. CEL still came on after reset. Is my 'cat' possibly bad? I was thinking of putting in a bypass component that '3800 performance' sells. It plugs in the existing connector for the 02 and tricks the computer into thinking the CAT is functioning properly.
Any other suggestions would be appreciated, besides replacing the 'cat'....$$$.
Old 06-28-2006, 02:48 PM
Default RE: CEL- code P0420
How does it run?
< CHECK OUT THIS LINK>
Old 06-28-2006, 04:02 PM
Check with the dealer, there is recall about the cat. I don't remember the details other than you only take it in if you have a power loss, etc... I think they extended the warranty time also.
Old 06-29-2006, 12:02 PM
01whitess's Avatar
Car runs fine, but I'm losing gas mileage. If I'm not mistaken the engine will run rich when you have this situation. I guess I will call the dealer.
Thanks for thr replies people !
Old 06-29-2006, 10:32 PM
Just because the O2 Sensor is throwing the code does not mean it needs to be replaced.
For example, if your car was running very rich, your O2 sensor would tell the computer there is a rich condition. If the computer sees it is too rich according to parameters in the computer, it will trip the check engine light, as it is effecting emissions output. Replacing the O2 will do nothing, as the new O2 will read the same because there is a problem elsewhere.
I am just using that as an example, not saying that is what is wrong with your car. O2 sensors can throw numerous codes and I am not sure which one that is. Intake leakage, high/low fuel pressure, leakng injector(s), low compression, exhaust leak, plugged cat, short to power or ground in O2 wiring, etc. can all throw O2 sensor codes.
As mentioned, there is an extended warranty on the cat, up to 100,000 miles I believe. At 52,000, mine went out, but I had a major loss of power as my symptom.
Edit- I just saw the link posted to what that code description is... oops. I'd put my money on the cat being bad
Old 07-06-2006, 08:45 PM
That is a cat code. There is no recall... but something called a "special policy" on it if the car falls within a certain vin range. Give me the last 8 digits of your vin and I will run it for you.
Usually when the cat goes bad, there is a marked decrease in vehicle performance and sometimes a rattling coming from the converter under load.
Here is a copy of the TSB...
Document ID# 1703629
2001 Chevrolet Monte Carlo
Subject: Special Policy Adjustment - Catalytic Converter #05551 - (09/14/2005)
Models: 2001-02 CHEVROLET IMPALA, MONTE CARLO
2001-02 PONTIAC GRAND PRIX
2001-02 BUICK REGAL
EQUIPPED WITH 3.4L (RPO LA1 - VIN E) OR 3.8L (RPO L36 - VIN K) V6 ENGINE
Condition
Some customers of 2001-02 Chevrolet Impala, Monte Carlo; Pontiac Grand Prix; and Buick Regal model vehicles, equipped with a 3.4L (RPO LA1 - VIN E) or 3.8L (RPO L36 - VIN K) V6 engine, may experience a condition where the vehicle exhaust catalytic converter is replaced due to complaints of lack of power or illumination of the Malfunction Indicator Lamp (MIL). This may be due to the front endcone insulation from the catalytic converter breaking away and blocking the front of the first catalyst brick and preventing the free flow of exhaust gas through the converter.
This special policy covers the condition described above for a period of 10 years or 120,000 miles (190,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership. The repairs will be made at no charge to the customer.
For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after September 15, 2005 are covered by this special policy and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to September 15, 2005 must be submitted to the Service Contract provider.
Vehicles Involved
Involved are all 2001-02 Chevrolet Impala, Monte Carlo; Pontiac Grand Prix; Buick Regal model vehicles, equipped with a 3.4L (RPO LA1 - VIN E) or 3.8L (RPO L36 - VIN K) V6 engine and built within the following VIN breakpoints:
Year
Division
Model
From
Through
2201
Chevrolet
Impala
19100001
19378250
2001
Chevrolet
Monte Carlo
19100001
19378233
2001
Pontiac
Grand Prix
1F100004
1F275188
2001
Buick
Regal
11100004
11338085
2002
Chevrolet
Impala
29100001
29374833
2002
Chevrolet
Monte Carlo
29100016
29374832
2002
Pontiac
Grand Prix
2F100019
2F276927
2002
Buick
Regal
21100001
21288762
Parts Information
Parts required to complete this special policy are to be obtained from General Motors Service Parts Operations (GMSPO).
Part Number
Description
Qty/ Vehicle
10343187
Converter, Catalytic (L36 engine)
Converter, Catalytic (LA1 engine)
Gasket, Catalytic Converter (Converter to I-Pipe, both)
Gasket, Exh Manif Pipe (L36)
Gasket, Exh Manif Pip (LA1)
Customer Notification
General Motors will notify customers of this special policy on their vehicles (see copy of typical customer letter included with this bulletin - actual divisional letter may vary slightly).
Service Procedure
Catalytic Converter Inspection
Begin the inspection by reviewing the condition described by the customer. Refer to "Description and Operation," SI document 657895, to help you determine the correct symptom diagnostic procedure when a malfunction exists. It will also help you determine if the condition described by
Old 07-07-2006, 09:46 AM
NYCRISS,
Are there any other special policies in place for the CAT on other Monte year models?
Old 07-07-2006, 08:35 PM
Not that Im aware of but if you post up the VIN of the car, I could tell you if there is a policy for it along with any other info about the car you may need.
Old 11-14-2007, 02:16 PM
dustybird3's Avatar
Photobucket
Monte Of The Month - April 2008
I know this is an old thread, but it sure saved me alot of $$$. Thanks NYCRISS! Turns old my new baby ('02 Intimidator) had one of those faulty cats. I would've never known it was still covered had I not seen this post and called GM, which in turn called the Chevy dealer here and got it all set up. Took her in today and got rid of that ugly check engine light (and a new cat) and didn't cost me a penny.
Thanks!!!
Old 11-19-2007, 11:39 AM
Hey Becky! Glad to hear your cat was covered. Big kudos to you for using the search feature rather than just throwing out a question. Your stock just went way up in my book.
Quick Reply: CEL- code P0420
