Break light switch
I'm having intermitent no brake lights. For instance, last night, I checked them and I had break lights. Then I checked running, turn signal and hazard. I checked the fuses and the bulbs. Everything, ok. I tried the brake lights again and only had the window light. But, as my wife pulled out to go to work, she had them. She still had them this morning, when she got home.
Driving me nuts. So, I think maybe the switch. It's 9 degrees and snowing,should be fun laying on my back, to check it. LOL! Is it located behind the pedal?
Thanks
Thanks
you have a bad multifunction/turn signal switch..... check out the thread below!
weird tail light problem
Ok, I'm ready to buy a turn signal switch. Any ideas/suggestions, as to a part number and where to buy? I checked rockauto and am confused as to which switch to get. I have tilt wheel and cruise but no radio control. They have 7 differant switches to choose from. 98 Monte LS
Thanks
Thanks
looks like some have cruise control and radio controls in the switch? not sure where you're at but do you have an Advance Auto near you? hope this helps????
http://shop.advanceautoparts.com/web...+signal+switch
hotrodharley
11-15-2013 11:37 AM
Snobird
05-06-2013 05:31 PM
gothkid
05-04-2009 09:54 AM
