brake light issues
Old 06-21-2011, 11:32 PM
Southguy's Avatar
Red face brake light issues
My right brake light works all running lights work turn signals work even third brake light works but left brake light does not . I have replaced bulbs wirinf is still in factory casing any help would be greatfull. Sorry everyone it's a 1999 monte carlo z34 have replaced brake light switch still not working I will try the turn signal switch. Thankyou everyone! !! :-)45
Old 06-21-2011, 11:40 PM
ok, might be helpful if you post the year of your car, thanks and welcome to the forum.....
Old 06-21-2011, 11:45 PM
you replaced the bulbs and did you replace the fuse? year would be helpful also i had a 97 Grand am gt that had the same prblem and i had replaced the bulbs an fuse so i took out the tail light case only to find it was filled with water. dumped it out let everything dry and it worked fine.
Old 06-22-2011, 01:18 AM
nitehawkjcb's Avatar
If it's a '95-'99, the multifunction (turn signal) switch is probably going bad
Old 06-22-2011, 02:25 AM
Southguy's Avatar
Smile
Sorry everyone it a 1999 Z34
Old 06-22-2011, 04:36 AM
Does the left brake light not work at all? Have someone step on the brake pedal and see if it lights up in the back.
I had this problem recently where mine right one wasn't lighting up like normal only when i pressed the brake it would come on. The thing i did was pump the brake a few times in park then flip the turn signal switch back forth a few times and seems to be working now like normal. Dont know if that a solution or maybe its dumb luck that it started working again like normal other wise you might be looking at replacing turn signal switch. i have a 99z34 as well.
Old 06-22-2011, 01:54 PM
As it has been said, Turn signal switch. I opted to take this one to the mechanic. Looks like a real SOB of a job. I think the part retails for like 50-70$.
matthew41
01-25-2015 11:22 AM
hotrodharley
11-15-2013 11:37 AM
heartbeat
01-14-2012 10:47 PM
matrx10503
RWD Tech Guides '70-'88
12-29-2011 10:33 AM
Bull
09-19-2010 06:34 PM
Quick Reply: brake light issues
