ac compressor kicks on and off every 5 seconds or so
Old 06-13-2011, 08:39 PM
M.C.BOB's Avatar
Default ac compressor kicks on and off every 5 seconds or so
Anyone else have this problem? Went to get the ac serviced over the weekend, correct amount of freon was put in, but they weren't sure what the problem was. Figures this would happen as the weather gets hotter and hotter
I'm not sure where to start first to check the problem, of if I should take it to another shop.
Old 06-14-2011, 12:12 PM
The most common problem with a compressor cycling like that is low freon...Maybe take it to another place to have freon level re-checked??
Old 06-14-2011, 12:26 PM
x2 they might not have put in enough, or you have a leak that wasn't diagnosed.
Old 06-15-2011, 03:20 PM
Same exact thing is happening with my 06 monte, also right after i did a re charge... No conclusion yet.
Old 06-22-2011, 02:10 PM
i alos had a question that relates to the thread my car has always had pretty cold air i turned on my ac and you could hear it kick on but nothing blows have it on full blast nothing changed settings time and time again and nothing. any advice
Cowboy6622
02-16-2013 07:48 PM
1998 z34
05-06-2011 11:40 AM
xjcurtisx
06-25-2010 11:13 PM
Absolutpolack
12-14-2009 10:02 PM
Absolutpolack
06-25-2009 12:15 AM
Quick Reply: ac compressor kicks on and off every 5 seconds or so
