antifreeze leak
Old 12-15-2010, 03:56 PM
mr202monte's Avatar
Default antifreeze leak
i change the waterpump and thermostat and seen antifreeze leakin in the back nea the thermostat
Old 12-17-2010, 06:47 PM
did u put a gasket for the thermostat housing if not do so and put some RTV sealant on the one side only and that side would be the side opposite the thermostat. i had the same problem til i put a gasket on the housing. good luck
Old 12-18-2010, 11:40 PM
nitehawkjcb's Avatar
Yep make sure the t-stat gasket is in place correctly, and you may need to use some RTV
Old 12-20-2010, 02:20 PM
mr202monte's Avatar
i did that and still leaking some where under the housing, what could it be
Old 12-20-2010, 10:10 PM
Under the housing is the manifold. Maybe an intake gasket leak.
Decoteaujr
04-19-2012 10:02 PM
mitch520
04-19-2009 08:59 PM
Sir Monte
02-20-2008 08:08 PM
hotrodss24
12-24-2007 09:58 AM
87lsman
06-06-2007 01:56 AM
Quick Reply: antifreeze leak
