Antifreeze flush
Old 03-24-2012, 06:30 AM
You guys are doing this the hard way. I work on many cooling systems at work and I flush all of them. Pull both rad hoses off at the engine. Use a garden hose with a sprayer and run water through one rad hose and out the other. Cycle back and forth between the hoses until clean water homes out.
Now, pull the t-stat. Stick the sprayer in the t-stat hole. Run water through until clean water comes out the other side of the engine.
Put t-stat back in and hoses back on. Refill system. Make to to be strong on the antifreeze mix because there will be a lot of water in the engine and lower rad.
Old 03-24-2012, 08:35 AM
Originally Posted by trewyn15
Why are you removing an air dam?
I removed the air dam because, the engineer's in their infinite wisdom, covered the drain **** with it The drain plug on my Monte Carlo is impossible to get to or find without pulling that plastic air dam!
No big deal, just 5 screws to remove. Then the challenging part was locating the drain **** It is kind of hidden just above the metal radiator housing on the drivers side.
Anyway, I am done with that bit of maintenance and thankful that I found this forum.
PS: I am now the proud owner of a Haynes Repair Manual.
Old 03-25-2012, 06:00 AM
You don't have to remove the air dam. Reach above the crossmember with a 19mm deep socket until you find the drain. It will drain through the air dam.
Old 12-15-2016, 08:12 PM
Default Backflush
So no one is suggesting a backflush except one person and it was on the radiator. Is it just not necessary?
Bringing this thread alive again!!
ashleymc34
30
11-01-2009 10:03 PM
jasonmcr
02-27-2008 07:43 PM
Sir Monte
02-20-2008 08:08 PM
hotrodss24
12-24-2007 09:58 AM
87lsman
06-06-2007 01:56 AM
Quick Reply: Antifreeze flush
