Antifreeze flush
https://montecarloforum.com/forum/sh...ad.php?t=12901
Check out the above link for infor
and also
check AutoZone.com 4 how 2 flushWikiAnswers - Where is the Radiator plug drain on a 2002 Monte Carlo
Where is radiator plug on 2002 Monte Carlo? Where is the radiator petcock on monte carlo? How Do Drain a Radiator on a 2000 Monte Carlo SS? How do you flush ...Check out the above link for infor
and also
wiki.answers.com/Q/Where_is_the_Radiator_plug_drain_on_a_2002_Monte_Carlo -
This is what I do....
I buy like 6 gallons on distilled water...and two gallons of coolant.
Drain the radiator, fill it with nothing put pure distilled water...run the car till it reaches operating temp, drain the radiator again, then fill back up with distilled water, and and run again till the car reaches operating temp...I repeat this about 4-5 time, or until the radiator starts draining nothing but plain clear water...Once you have nothing but distilled water in the system, drain the radiator, and fill it with nothing but 100% concentrate coolant, and top off the coolant over flow too. Then run the car for a while, and check coolant level again, topping off with straight coolant.
This gets you pretty damn close to a 50/50 mix of water and coolant, and flushes all of the old coolant out of the system...
Using distilled water is better for your cooling system, because it keeps hard water deposits from forming in the cooling system....
mamonte is correct on the method, but opening the bleeder valves while running to warm up helps .also, give time to cool down between flushes. about to do mine now ironically, about 2000 miles ago my father and i replaced the water pump and a flush. opened the hood yesterday and noticed "mud" in the overflow. used prestone before, must have been bad stuff! going to do it AGAIN, but using dexcool this time.
Dexcool will form that "mud" when exposed to air, or when mixed with another type of coolant.
-Riggs.
That mud is likely sludge from the old dexcool that didn't get fully flushed out when you did the coolant flush. 2000 miles of new coolant being in there finally forced all of the dexcool pudding out of the block and radiator, and now you're seeing it in your radiator tank.
-Riggs.
-Riggs.
If I was you, I would flush it again, but I would put the Prestone in it again, and would not switch back to Dex-cool...
After only 20K, I've had Dex-cool literally turn to Jello in my overflow container...I personally think Dex-cool is crap. I've changed mine twice already in my car with 72K, and like I said before, as soon as my warrenty is up, i'm getting rid of Dex-cool forever.......
