cooling system problem
Old 01-13-2011, 08:01 PM
augi's Avatar
Default cooling system problem
Soundsvague I know, but I am just trying to figure this out... and its boggling. Car runs fine, watching temp gauge, it doesn't go up to regular operating temp unless sitting idle for a long period of time. That being said, when it does go up to operating temp, it still fluctuates reg temp/ cold (around 160). The heater isn't blowing very hot at all unlessthe car is under load. Coolant is full, thinking bad thermostat ( stuck open maybe?) Any guesses?
Old 01-13-2011, 08:37 PM
You are sure there are no coolant leaks, right? My car did the same things and it turned out to be a little elbow pipe that broke, causing coolant to spray everywhere
Old 01-13-2011, 10:15 PM
augi's Avatar
Those are brand new
* update*
I opened the hood and the upper radiator hose sucked in on itsself, I loosened the radiator cap and it immediatly filled back up with coolant and the heater got warm. I felt the hose and it was full of fluid after the radiator cap got loosened.
Old 01-14-2011, 10:17 AM
Did you bleed the system?
Old 01-14-2011, 01:15 PM
No heat and the car temp being low would point me to a open thermostat. It also sounds like you have a lot of air in the system with the upper hose sucking itself in. I would change the thermostat and bleed the cooling system really well.
Old 03-17-2011, 03:02 AM
I'll be watching this thread...my '03 is behaving in a very similar way as what you described.
I've read about checking the elbows so I will visually inspect...but I dont see steam and no leaks under the car.
I'll change the stat and observe for changes.
Has the problem now gone away for you ?
Old 03-17-2011, 03:06 AM
and the not paying attention to the forum award goes to.....
Old 03-19-2011, 05:13 PM
I don't get your comment...is that thrown at me or to the original poster ?
I'm just wondering what the update might be...sorry if I missed something.
Thx
John
Old 03-19-2011, 05:33 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
https://montecarloforum.com/forum/en...-engine-26459/
^^^I am pretty sure that he is in the process of getting a new engine. Just click that and it should get you up to date.
Old 03-20-2011, 05:38 PM
augi's Avatar
Lmao... greg would be correct.
The problem was, the water pump was leaking and the upper intake manifold had a leak to the inside.
You should change that gasket every 60,000 miles.
I do have a new engine now, but its sad that I had to sacrifice an engine to learn that
Quick Reply: cooling system problem
