1998 MC with 3100 engine - basic maintenance questions
Hello guys,
I wanted to do some work on my wife's MC and have couple of questions.
1. Cooling system - I wanted to overhaul cooling system. Car just hit 100k miles and lower hose is leaking - should I perform complete overhaul at this mileage or just take care of the leaking hose? If just the hose, would you recommend aftermarket parts or should I go OEM?
2. Anti lock light came up - I've read here on the forums that it is due to the speed sensor failing in the hub thus the hub needs to be replaced but I would appreciate if someone could share some more knowledge about this.
Is there a DIY knowledge base on this forum?
Thank you,
Lucas
Thank you,
Lucas
Lucas,
If the car is not having cooling issues and has been well maintained, I'd recommend just doing a thorough flushing of the system. Wouldn't hurt to take a peak inside the radiator to see if it has significant build-up of crud.
As for the hose, their all pretty much the same. See what your local auto parts store can supply.
Sorry, not much help on #2.
Thanks, would local autoparts store be able to read it or do I have to swing by the stealership?
BeachBumMike
11-06-2007 08:47 PM
