1987 305 350 ENGINE SWAP
Old 02-11-2008, 11:29 AM
willie8701's Avatar
Default 1987 305 350 ENGINE SWAP
IS THERE MUCH TO SWAPPING OUT A 305 FOR A 350 IN A 1987 MONTE .
Old 02-11-2008, 12:13 PM
Default RE: 1987 305 350 ENGINE SWAP
[align=left]
ORIGINAL: willie8701
[/align][align=left][/align][align=left]Hi Willie, I hope the below links give you some of the[/align][align=left]information that you need. It should be adrop in install.[/align][align=left]Let us know what you do ?[/align][align=left]Have you searched out any Peformace Car Clubs in the[/align][align=left]Cincinnati area ? Or stop in a one of the local performance[/align][align=left]shops, and they will assist in information/cost.[/align][align=left]Also, I would order a Jeg's Performance Catalog on the[/align][align=left]Chevy 350's[/align][align=left]Be Patience, and I'm sure one of our expert member's will[/align][align=left]post information on your question... like Moderator `Boost.[/align][align=left]Good Luck![/align][align=left]Chevrolet Small-Block engine[/align][align=left][:-][/align][align=left]http://en.wikipedia.org/wiki/Chevrol...l-Block_engine[/align][align=left][/align][align=left][/align][align=left]What do I need to be aware of when swapping a olds 305 to a ...
What do I need to be aware of when swapping a olds 305 to a chevy 350 in a 1981 Cutlass Supreme? ... In some states the engine change may not be smog legal. ...
answers.yahoo.com/question/index?qid=20080105082... - 42k - Similar pages
http://answers.yahoo.com/question/in...5082112AAsEqKH
Where can i get a USED Chevy 305 or 350 small bloc...
I would like to get a 305 or 350 V8 Small block, the prices of a new crate engine are way too high for me, so does anyone know of a good site to get an ...
answers.yahoo.com/question/index?qid=2007... - 62k - [URL=http://aolsearch.aol.com/aol/search?invoc
Old 02-11-2008, 06:41 PM
NO THERE IS NOT MUCH TO CHANGING A 305 FOR ANY OTHER SMALL BLOCK CHEVY MOTOR THAT WAS A REAR WHEEL DRIVE.
YOU CAN CHANGE IT TO A V-6 EVEN IF YA WANT TO.
BTU IT WILL FIT ALL THE WAY UP TO A 400 SM. BLOCK.
THEY ARE THE SAME BLOCK JSUT A DIFFRENT BORE AND STROKE. YOU CAN EVEN INTERCHANGE PARTS FOR THE TWO OF THEM LIKE HEADS ETC...
I USED TO DO THIS ALL THE TIME TAKE YOUR 305 HEADS AND HAVE THEM WORKED OVER AND PUT THEM ON THE 350. GIVE YOU A SMALLAER CHAMBER CC IN THE HEADS. THSI WILL ALSO MAKE YOUR COMPRESSION RISE SOME.
DO THSI WITH A SMALL CAM AND YOU HAVE A GOOD STREETABEL MOTOR AND ALSO A FUN TOY TO DRIVE ON PUMP GAS AND NOT TO BIG OF A PINTA
OH BY THE WAY WE NORMALLY DONT YELL IN HERE. JUST FIGURE I WOULD SO YOU COULD HEAR ME
we normally talk like this. LOL
Old 02-12-2008, 08:25 AM
yup ! the great thing with our monte's is that it acepts any motor in the chevy stable with little or no modifications
the the90*chevy v6 any sbc or bbc just make sure you use the motor mounts from the car thats all the truck mounts are taller and wound bolt in
but they are a basic swap get prepard of anything because suprises alwayz come up but is a straight forward swap
good luck with that and keep us posted on your progress
porshapower
11-02-2012 07:58 AM
adamlessor
06-22-2009 12:16 PM
monte84
07-15-2007 09:03 PM
3Gs
04-09-2007 01:18 PM
Quick Reply: 1987 305 350 ENGINE SWAP
