1985 monte ss right turn signal on when lights are on and buzzin
hey. i started my car just now. i just got it. well i started it anfd then turned ont he lights. well the righ turn signal is on and its buzzing...its an 85 monte ss....let me kno please.....thankz everyone...
RE: 1985 monte ss right turn signal on when lights are on and buzzin
My blinkers were messed up on my '86 LS when I got it. It was before I started tinkering with cars, so I don't know exactly what my dad did to fix it. I'm guessing on this, but I think there was is a multifunction switch in the steering column that needed replacement. Also, that lil blinker can is cheap to replace to eliminate a possability.
If a turn signal or hazard flasher won't stop the problem then I would check front and rear parking and tail lights for a bad ground or short. (I had a bad light socket in my left rear tail light of my '86 Monte.) If that doesn't work, put a new turn signal switch in the steering column.
Redline29
03-30-2019 03:46 AM
taz7nads
07-19-2012 09:38 PM
