Removing Fog Light Assembly 06 MC
I'm looking for the proper way to remove the complete fog light assembly. I cannot find anything on this. Any info would be greatly appreciated. Thanks, community.
Fog Light Assembly
Access to the lights/assembly is not my issue. It's removing the fog light assembly. The whole thing. Not just the bulb. The assembly is press fitted in the housing. I need to know how to remove it "properly" without breaking it.
Understood. The fog light assembly is accessable from the back side of the bumper fiacia, and to get to it the headlights need to come out. The fog light assembley is directly under the head lights
No. You still do not understand. Take out your headlight and remove the bulb from the fog light. Then tell me how you would remove your fog light assembly. You do not necessarily need to remove the underbody trim/rock guard. Look at the assembly closely. Then tell me how you would remove the "whole thing" from the body.
I'm almost positive it's like the 2000-2005 ones. If so, Tadcaster's directions are correct. Take out your headlight so you can reach down to the fog. If you're talking about removing the whole assembly so there's a hole left in the bumper it's a clip that slides onto a slot coming off the bumper interior, then at the top of the light (in front of the light, in the exterior bumper a screw holds it in. Remove the screw and clip, remove the bulb by twisting it and the whole thing comes out.
I installed fog lights on my 2000, I had the vent grates in place originally.
I had to remove the whole fog light assembly in my 03 ss to install strobe lights and it was a bit harder than I thought it would be. The concept was easy enough but the clips were kind of rusted on real tight. Had to just force it off and luckily I didn't break anything
