Windshield washer pump fuse location?
My son has an 07 Mont Carlo that has a non functioning pump.
I was trying to figure out where the fuse may be located if there is one. He has no manuals to go by and I figured to find that first before replacing the pump.
Also will check hoses after but don't see leaks. It's just not making any noise.
Thanks!
Thanks!
I looked for location in my Haynes Repair Manual.
In the underhood fuse block, there is a 25 amp fuse for wipers.
There is a wiper low relay, wiper high relay and a washer replay.
Washer relay is what you want to check.
Repair Guide: how to change windshield washer fluid pump
nemesis
FWD Tech Guides '95-'07
06-08-2012 12:02 AM
