Replaced CKP - Car will not start + pop noise
Hello, new here and have been lurking since I've owned my 2001 Monte SS. This site has proved to be incredibly helpful with problems that have been answered in the past however it is of my great displeasure to actually have to post a thread of my own.
Prior to me tackling this job my car was in good working order other than the stalling/occasional loss of power. I have had the problem with the sensor for longer than I'm willing to admit, I was never bothered enough by it to have it changed sooner. Finally decided to take on the task today, and other than a few hiccups the installation went well. I used the starter method to loosen the HB bolt, took a few tries to get her loose.
When I attempt to start the car it cranks and it seems like it wants to start but instead I hear some kind of pop noise and a small amount of smoke arises from around the throttle body area. I am absolutely stumped on what to do here. If you need any more information I will provide. Thank you for looking.
I will state an additional observation, it appears that the longer the car attempts to crank the more smoke arises. Also I will note that my car has always seemed to make a high-pitch whine noise, however that did not interfere with the performance. That's all I got for now.
I believe it's the proper abbreviation for Crankshaft Position Sensor though I've seen it called CPS too; which is more understandable.
This morning I took out the MAF and cleaned her up nicely, gave another try at starting and smoke starting arising from another place. If you were standing at the front of the car, the location of the smoke would be underneath the top left corner of the engine cover.
I really wish I had more tools to check different aspects of the car.
The only thing I can think of that I did wrong was the way I held the flywheel while using the starters torque to loosen the HB bolt. I don't see how something major could have gone wrong that won't allow the car to start when it was just sitting untouched.
Can't be anything major, only related to the work you've done. Sounds like an electrical connection is somehow backwards. The starter wires hooked up wrong is where I would start...The "smoke" - is it electrical or from the engine?
I started a thread about year prior to yours with exactly the same problem. In case you still need advice, see it here:
https://montecarloforum.com/forum/mo...acement-48355/
Opinion Needed: 2000 MC SS: Big problems after CKP replacement
Linus
11-28-2015 06:25 PM
shawna75
09-25-2012 08:04 PM
raikel.conerly
07-09-2009 09:52 AM
