Opinion Needed: 2006 monte carlo abs/traction control problem
Hello, my 06 Monte has traction control and abs lights on when turning the wheel or going over bumps. I had the Code read and it come up as right side wheel speed sensor. I replaced the hub. Now both lights are staying on. I have checked all the wireing everything seems secure and tight. any thoughts of what could possibly be tripping these codes? Thanks in advance for any advice.
abs
Ya, I tried cleaning the connection also with no luck. Replaced the hub assembly twice, and both front harnesses are putting out same voltage, so I don't think it's a harness. I am baffled, only thing I can think of is the replacement Hub is a cheaper one and it just doesn't agree with the computer...
Did you ever figure out the problem? I've been going through the same thing on my '06 SS - had the passenger side front and wiring harness replaced...car ran/drove well for about a month, now the driver front is acting up on sharper turns - the traction control is engaging for no reason ...though no service brake assist or service traction control messages yet.
