5th Gen ('95-'99): Info Request - Trim Tool
Old 01-05-2017, 09:08 AM
Pumper253's Avatar
Default Info Request - Trim Tool
Trying to locate the correct socket to remove trim nuts from '97 Monte rear interior trim panels, that keep both rear side trim panels together. Local sources don't have listing for anything close.
Old 01-07-2017, 08:57 AM
Monte Of The Month -- May 2015
Monte Of The Month -- March 2017
Smile
I had a similar issue and the dealer technician told me these are a push on nut and the stud is plastic. So about the only thing you can use is a needle nose pliers
