JL Audio Clean Sweep (Factory amp bypass needed???)
Old 05-10-2009, 10:50 PM
montess2k4's Avatar
Default JL Audio Clean Sweep (Factory amp bypass needed???)
I am planning on installing a JL audio Clean Sweep in my Monte. I have been reading about the factory amp bypass. It is still not clear to me when it is needed or if it is needed at all. I am going to keep the factory radio in my car. I have aftermarket interiors and 1 12 inch sub. I am going to use a 4 channel amp to power the interiors and a 1 channel mono amp to power the sub. With this set up will a bypass be needed? To me it makes sense to bypass the amp because I will have another to replace it. Any help will be appriciated. Thanks!
Old 05-10-2009, 11:54 PM
I sell Jl products and can personally tell u the clean sweep is an amazing machine lol. I dont know if you will need to bypass the factory amp but I know in my car I did and really ur absolutely right it serves no purpose wit ur set up
Old 05-11-2009, 10:38 PM
i looked into it before, i was told i would need to buy a bypass/conector for about 130 bucks. i too wonted to keep the old amp and just add two 12,s. also somehow without the bypass it would affect the onstar and the message center ?!
Old 05-12-2009, 09:53 AM
montess2k4's Avatar
Old 05-12-2009, 06:35 PM
bestkits.com will tell you everything you need to run aftermarket audio
Old 05-12-2009, 10:37 PM
thats what it was, a bypass harness!
Old 05-13-2009, 03:19 AM
The factory amp can be bypassed with a $10 bypass jumper.
Or you can find the how to online and do it yourself for free
Old 05-13-2009, 10:37 AM
montess2k4's Avatar
Thanks for all the help! Looks like I'm buying the one I found on ebay.
Old 05-13-2009, 11:08 AM
montess2k4's Avatar
Is this what you are talking about?...http://www.sonicelectronix.com/item_...a+70-2021.html
I have a 2004 and this is for a 00-01. Its says that it "Allows for the installation of an aftermarket radio using the existing factory wiring and connectors" I'm not installing a aftermarket radio, just the JL Clean Sweep. Will this do the job?
Old 05-13-2009, 09:49 PM
That is the one I was talking about......I has seen a how-to online but after looking at it again I realize it didn't specify what years Impalas/Monte Carlos that bypass worked on. I stand corrected.
After looking into it more, you have infact found the correct bypass harness!
Quick Reply: JL Audio Clean Sweep (Factory amp bypass needed???)
