Audio/Video Build: soxin's audio thread
So far I've got an eclipse cd7000 Headunit and a 1200w Sony amp to a 12" dual sub. The sub will change and I'm doing 6.5 component in front and 6th coaxial in the rear with an eclipse 1000w 4 channel amp.
Got my leather seats in! Now I have to finish getting all the interior pannels switch out for Black ones.
Thanks. I made the screen in photoshop. It had cloth leather seats in it for some reason. I thought all ss models had leather especially the hs/ss which I have. I might keep it as is. What do you all think about the Grey and black interior or should I go all black.
I have onstar but i don't use it so i used the 12$ harness kit. Was very easy to install. For the accessory power it came with a fuse tap and you just tap a fuse that's only on with the key. I had a 7" screen in there but I have yet to find a double din with as good of sound quality as the eclipse.
Your interior is sort of like mine cause I have the grey and black set up and I have grey cloth bucket seats too. It is weird cause I have an ss as well. I do like the the black and grey cause it does match but the only things i changed was like all my dash pieces so it goes from like black to grey from front to back.
04MonteLS
09-03-2005 01:05 AM
