How to reset GM message center with an aftermarket receiver - Monte Carlo Forum - Monte Carlo Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 02-13-2007, 11:35 PM
Default How to reset GM message center with an aftermarket receiver
How can I reset various warnings in the message center of my 2000 Monte Carlo without the factory receiver installed. I have a kenwood receiver with this device http://www.crutchfield.com/S-g3EWWdb...51&I=120GMRC01
When I start my car up it beeps 30-40 times consecutively for low tire pressure, change engine oil, low washer fluid, low coolant level. Before the aftermarket receiver was installed, you would reset these warnings by using the factory receiver. Please help, I can't find the answer to this anywhere.
Old 02-14-2007, 12:27 AM
RocknSS04's Avatar
Default RE: How to reset GM message center with an aftermarket receiver
Your owners manual should tell how. My wifes Silverado resets the change oil message by pushing the gas pedal 3x with the key on, but not running. Something similar for the tires. Auto Zone for free check engine light diagnostics.
That's why I remote mounted my factory radio in my trunk, to access the computer easily.
The fluid levels I would think would befaulty level sensors or corroded wiring, if the levels aren't low.
You should be able to reset all messages without your factory radio.
Security and delayed lighting, etc.are impossible to access without the radio, tho.
http://www.cardomain.com/ride/2319272/2
Old 02-14-2007, 01:04 AM
I had the factory receiver mounted in the back at first, but the way it was wired, it kept draining the battery.
Thanks. I'll try your suggestion, and probably go to Autozone for the diagnostics.
Old 02-14-2007, 02:50 PM
Everything is gone except for low coolant level.
Old 02-17-2007, 08:26 AM
RocknSS04's Avatar
Your coolant level sensor is probably corroded then, or a bad connection. There is no reset for that. Only resets are tire pressure and oil life.
Actron makes a OBD2 scan tool for $79 at Auto Zone that works great for your check engine light, to do it yourself. Ask my son, he has mine!
Reply
Thread Thread Starter Forum Replies Last Post
message center problem (lights) peoples 01 ss Monte Carlo Repair Help 8 08-17-2016 10:58 PM
security light on in message center 03Montepacecar Monte Carlo Repair Help 13 07-24-2013 05:40 PM
Possible To Use Stock XM Receiver With Aftermarket H/U? Snyderman Interior/Audio/Visual Electronics 3 08-26-2010 07:48 PM
Change Engine Oil Message Center Light PackedFunk Monte Carlo Repair Help 5 03-03-2010 06:10 PM
Reset Oil Change Message 01montesf Monte Carlo Repair Help 8 07-15-2009 06:43 PM
Tags
2000, cardomaincomride23192722, carlo, center, chevy, coolant, factoy, fluid, level, life, low, message, monte, oil, radio, reset, washer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
