2002 monte carlo factory stereo
I have the whole setup in my 01 MC SS, but the thing is is that I figure I did the installation correct and come to find out that I didn't. I installed the L.O.C. (Line Out Converter) to the radio harness and ended up with no sound. So I was thinking "maybe instead of the loc being tap into the front speaker wires, they need to be on the rear speaker wires". Which the result came out to "STILL NO FEED FROM THE SUB". So my nexts guess is the rca's that I have, maybe its a short in it or so. If I can't pinpoint my faults, then I will need a loc, amp and sub installation guide for DUMMIES or so. LoL!!!!!!!!!!!!!
I figured that, I do have the harness with the chime because after those guys stole my system, my headunit was still in the trunk (thank goodness). So I will use it. I was about to throw that harness away because I am not tryin to put an after market stereo back into my car. Thanks for the insight.
I had my system installed with the help of a couple of friends and they used an axxess kit from metra. The install went well except for the hi/mid amp wiring. They wired that amp into the factory amplifier. Needless to say, they almost blew the factory amp. I'm wondering if I can rewire the new amp to the 4 speakers and then wire the factory amp to bypass the new amp at the front speakers so as to be able to use the onstar? Right now the onstar is disconnected so the new amp can be use.
Hey montyss, there is a poll on here about how to wire the aftermarket amp to the factory or aftermarket speakers (whateva's your choice) and bypass the original amp for better sound. My guess is that you should be able too because the factory amp is already wired into your original system, I think (I could be wrong also) that you can cut the speaker wires from the factory amp harness, add extra wire to the speaker wire and connect those to your aftermarket amp. That's what I'm thinking at least.
Radio or Amp issues
My wife has a 2004 Monte Carlo. The sound has been going off and on for the past few months. Now she has no sound from the radio. We are not sure if it's the amp or radio? Can we test? If not, then I want to install a aftermarket radio. If I do can I eliminate the AMP? Any help would be awesome. Please email me at doberman@rittermail.com
Hello forum! I am very new to the site but I have been the proud owner of my Monte for a few years now. However recently my factory amplifier quit working on me. I put my voltmeter on the pins listed as power and ground and I do not have any power. When I leave my ground coonected to the plug and test the "B5" pin I have 9.xx but nothing at "A3". Anyone have any ideas? What fuse should I be checking for power as every fuse I have checked so far appears to be in good working condition. Thanx for your help in advance.
Chris
Chris
