2002 monte carlo factory stereo
Old 04-24-2008, 08:15 PM
paddock's Avatar
Default 2002 monte carlo factory stereo
I'm just tryin to figure out the factory wiring for the stereo. Does that little amplifier in the trunk power the entire system. Or is it just for the rear speakers, and the deck control the front speakers?
Old 04-24-2008, 08:24 PM
Default RE: 2002 monte carlo factory stereo
I think the amp in the trunk is just for the rear speakers.
Old 04-24-2008, 08:29 PM
The rear amp powers the front and the back speakers.
Let me know what you're wanting to do and I may be able to help you out. I've explored every inch of the factory system, from the headunit to the amp, and back to the speakers. Just don't ask me about colors because I'm color blind... [:@]
Old 04-26-2008, 01:21 PM
paddock's Avatar
I'm looking to put a system in the car. But I'm gonna keep the factory head unit. I procured an Audio Control LC6, where all you have to do is plug the speaker wires in to the unit and you get the Pre-outs that you need for aftermarket amplifiers.
this is what i got
http://www.mobileaudiocontrol.com/pr...oduct_Id=31215
Old 04-26-2008, 02:45 PM
Oh, then I think all you really need to know is this:
Radio 12v
orange
radio harness
Radio Ground
black
radio harness
Radio Ignition
(Class 2 Serial Data)
Radio Illumination
gray (dimmer)
radio harness
Factory Amp Turn-on
same as power antenna wire
Power Antenna
white
radio harness
LF Speaker +/-
tan - gray
radio harness
Notes: If equipped, the amplifier is under the rear deck.
RF Speaker +/-
lt. green - dk. green
radio harness
LR Speaker +/-
brown - yellow
radio harness
RR Speaker +/-
dk. blue - lt. blue
radio harness
I don't know if you already had that, but that's all I really needed when I did my system. This is everything coming out of the stock headunit though, not out of the rear amp.
Old 06-26-2008, 03:53 PM
i am adding a LOC so that i can add a sub and amp, i know how to wire everything up, except the remote wire. i have wired it on a aftermarket hu, nut i dont know what to do on the factory HU. thanks for your help
Old 06-26-2008, 04:18 PM
paddock's Avatar
this is the plug for the amp in the trunk.. the bigger of the two plugs..
here's the wire map
Pin Wire Color Circuit No. Function
A1 BLK 1051 Ground
A2 Not Used
A3 ORN 2640 Battery Positive Voltage
A4-A8 Not Used
A9 LT BLU 115 Right Rear Speaker Output (-)
A10 YEL 116 Left Rear Speaker Output (-)
A11 DK GRN 117 Right Front Speaker Output (-)
A12 GRY 118 Left Front Speaker Output (-)
B1 BLK 1051 Ground
B2 Not Used
B3 ORN 2640 Battery Positive Voltage
B4 Not Used
B5 WHT 1487 Antenna Enable Signal
B6-B8 Not Used
B9 DK BLU 46 Right Rear Speaker Output (+)
B10 BRN 199 Left Rear Speaker Output (+)
B11 LT GRN 200 Right Front Speaker Output (+)
B12 TAN 201 Left Front Speaker Output (+)
The antena enable wire is the remote turn on!
Old 06-27-2008, 06:00 PM
thank you, i must say that wireing the LOC is easy and it is much harder to run the power wire in the car. i hooked up a old MTX 10' 400w to a 300w amp and it sounds pretty damn good for what it is, next i just need to swap out the speakers. i must say that if you go to best buy and get the pigtails for the factory plugs for the speakers it is much better and easier to install, no cutting and not wiring at all, just plug it in.
Old 10-11-2008, 04:59 PM
ok i have a 2002 monte SS and i get lights through my stereo and dash onstar lights up and everything seems to work but i have no sound what so ever all radio, chimes and warning sounds are disabled and i am gettin rather frustrated any help would be appreciated
Old 05-30-2009, 03:15 PM
Default Hey
here's the wire map
A1 BLK 1051 Ground
A2 Not Used
A4-A8 Not Used
B1 BLK 1051 Ground
B2 Not Used
B4 Not Used
B6-B8 Not Used
Hey everyone! I have a 00 SS and its got the amp in the back. I have a very irritating problem where the whole sound system does not work most of the time, but pccasionally Ill get sound out of the speakers. HU works just fine. Tried replacing with another known working radio, same issues. No chimes from IP. Used to be where it would cut out occasionally, now it only comes on, but very rarely and for maybe 1 second at a time. Yes, one second.
the only other thing I can think of is that there is wiring under the carpet that goes to speakers or the amp that is shorting... someone point me in the right direction?
Quick Reply: 2002 monte carlo factory stereo
