1400 watt kove amp
RE: 1400 watt kove amp
the rear tail lights or running lights would work off of your head light switch on the dash
other wise just run it to your stereo in the back most have a ant.wire or a remote wire on the after markets ones
if you are looking for one thatis in the fuse pannel get a test light from a local store cheap and then just find one that turns on and off with the key power JUST LEAVE THE AIR BAG FUSE ALONE!!!! DO NOT USE IT FOR ANYTHING !!!!
DONT EVEN USE A TEST LIGHT ON IT!!!! COULD CAUSE YOUR AIR BAGS TO DEPLOY!!!
