3.4 intake swap on 3.1 engine - Monte Carlo Forum - Monte Carlo Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 03-01-2010, 10:51 PM
cangri_926's Avatar
Question 3.4 intake swap on 3.1 engine
i was reading and searching for mods and info to get some more horses with out spending a crazy budget,anyone had done this swap??anyone know the budget range and problems i compare a 3.4 alero from my friend and even the egr seems to be in a correct place,i did notice coolant lines may vary as they run from the coolant reserve towards the thermostat side of the water hose.any help will b appreciated
Old 03-02-2010, 05:08 AM
Wilco's Avatar
Have you thought about swapping a 3.8+trans+axles instead? Maybe even a supercharged one? Monte Carlo's came with 3.8 in 99. You would need the engine, trans, axles, PCM, wiring, maybe radiator, alt, starter, and a few more things you could get from the donor car. Worth taking a look!
Old 03-02-2010, 07:49 AM
cangri_926's Avatar
Quote:
well never thought of it but its a great idea,then again i live at a apt complex also work here,and the only one i know with a mechanic garage is mu cousin witch i dont think can work with,being fam on a open sunday that he doenst use the shop wanted me to pay him little upper the 300.and well i dont have a place to do that,i know mechanic not a pro but i try.but now that i said that will save a budget and look around for a z34 witch is the 3.8 and i do have seen mods including headers for it.but i wish i can find it white but i think omly the luminas are.thx again for the help
Reply
Thread Thread Starter Forum Replies Last Post
6th Gen ('00-'05): Noise after intake manifold swap S1knes Monte Carlo Repair Help 0 06-27-2014 12:28 PM
Tired of searching! 98 ls 3100 to 3400 intake swap Bigray1111 Engine/Transmission/Performance Adders 5 01-17-2013 07:12 AM
3.4 for 3.4 swap... any suggestions before I swap it? Budsjlm Engine/Transmission/Performance Adders 9 04-03-2012 06:43 PM
Intake question - post L67 swap kc2kth Headers/Intake/Exhaust 2 09-12-2010 02:42 PM
06-07ss ls6 intake swap TheMonteMan Headers/Intake/Exhaust 0 11-27-2009 04:53 PM
Tags
31, 31engine, 34, 34intake, carlo, engine, intake, mechanic, monte, motor, place, put, swap, top, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
