Welcome to the Monte Carlo Forum - Monte Carlo Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
I am trying to figure out why the climate control only blows air on the floor and defrost vents. I checked the vacuum line at the back of the engine, and under the passenger side toward the center council. Both are hooked up with no leaks. What else could be causing this? The temperature control works fine.
__________________ The Hot Rodders Prayer:
As I lay rubber down to street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride. -Amen
