Monte Carlo Forums
Go Back   Monte Carlo Forum - Monte Carlo Enthusiast Forums > General Forums > General Tech
Sign in using an external account
Register Forgot Password?
Search
Welcome to the Monte Carlo Forum - Monte Carlo Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Reply
LinkBack Thread Tools Search this Thread
Old 06-21-2011, 11:32 PM
Red face brake light issues
My right brake light works all running lights work turn signals work even third brake light works but left brake light does not . I have replaced bulbs wirinf is still in factory casing any help would be greatfull. Sorry everyone it's a 1999 monte carlo z34 have replaced brake light switch still not working I will try the turn signal switch. Thankyou everyone! !! :-)45
Old 06-21-2011, 11:40 PM
ok, might be helpful if you post the year of your car, thanks and welcome to the forum.....
__________________
Chris #3 FOREVER
2006 3.9 LT3, CAI, dual Magnaflow mufflers and 4' tips.....
& a 1999 Z34 added to the family 8-19-11....
CODE: CPE1704TKS.......
Old 06-21-2011, 11:45 PM
BlackRainSS's Avatar
ScarsNeverHeal13
you replaced the bulbs and did you replace the fuse? year would be helpful also i had a 97 Grand am gt that had the same prblem and i had replaced the bulbs an fuse so i took out the tail light case only to find it was filled with water. dumped it out let everything dry and it worked fine.
__________________
2005 Monte Carlo SS Supercharged
1995 Dodge Stealth R/T
2000 Ford F150 XLT
Old 06-22-2011, 01:18 AM
nitehawkjcb's Avatar
If it's a '95-'99, the multifunction (turn signal) switch is probably going bad
__________________
http://www.cardomain.com/ride/788651
'96 Monte Carlo, '93 Prelude
April 2012 MOTM
Us: At Your Service | Expert PC Computer Repair
13.81@102
Old 06-22-2011, 02:25 AM
Smile
Sorry everyone it a 1999 Z34
Old 06-22-2011, 04:36 AM
Does the left brake light not work at all? Have someone step on the brake pedal and see if it lights up in the back.
I had this problem recently where mine right one wasn't lighting up like normal only when i pressed the brake it would come on. The thing i did was pump the brake a few times in park then flip the turn signal switch back forth a few times and seems to be working now like normal. Dont know if that a solution or maybe its dumb luck that it started working again like normal other wise you might be looking at replacing turn signal switch. i have a 99z34 as well.
Old 06-22-2011, 01:54 PM
DerEin's Avatar
As it has been said, Turn signal switch. I opted to take this one to the mechanic. Looks like a real SOB of a job. I think the part retails for like 50-70$.
Reply
Tags
1999, 2006, 96, 97, blinker, brake, carlo, install, light, lights, monte, parking, problems, replace, switch, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
