Monte Carlo Forums
Go Back   Monte Carlo Forum - Monte Carlo Enthusiast Forums > General Forums > General Tech
Sign in using an external account
Register Forgot Password?
Search
Welcome to the Monte Carlo Forum - Monte Carlo Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Reply
LinkBack Thread Tools Search this Thread
Old 06-10-2007, 07:43 PM
Default 2004 monte carlo ls large evap leak
Have a large evap leak code. Was wondering if anyone had a link showing the evap system. Will be purchasing a new gas cap in the mean time to swap out. Hopefully this will be all. Although I am doubting that the gas cap is the problem. Tried listening for a leak back by the gas tank and under the hood but didnt hear nothing nor knew where to look. Any help appreciated.
Old 06-10-2007, 09:45 PM
wiz kidd's Avatar
Default RE: 2004 monte carlo ls large evap leak
that is most likely what it is, best to start with the cheapest and most common things
__________________
Old 06-11-2007, 12:03 AM
Senior Member
First thing i would check would be the pcv valve, check to make sure that it is working and that it has not come apart, check the hose that is going to the valve
Second
Somewhere under the hood should be a decal showing the vac. hose routing. This should include evap system.
__________________
Proud owner of a
2006 Monte Carlo LTZ
Laser Blue
Reply
Tags
04, 2004, 2005, canister, carlo, chevy, code, evap, hose, large, lark, leak, location, monte, ss
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
