what manule trans is this???
i got this from a guy at work today. for a really good price...
i just dont know how to go about finding out what it is, what it might be worth?i know its a gm, but munci, saginaw.... i have no clue??
also, would this trans be somthing that could be put into an 84 monte carlo?? or would it just not work. i am not aware of ant manule montes, but i dont see why it couldnt be done??? i know it would take a lot of inginuity, but do you think it could be done, and worth it???
thanks so much guys, brian
found some info....
okay. i think that i figured it out. i believe its a saginaw because of the three shift levers being on the side cover with 7 bolts. its also all cast iron.
i keep searching on the net to see if they are hearty transes, but all i can sem to find are people who love them, or hate them, but none really gives any reasons why ??
anyone here have any good, or bad experiance with saginaws? i am wondering if this would be better thn a 700r4 or not?
RE: found some info....
Hi `Brian,
Below are some sites that may help with your search. Good Luck!
M&R Racing Equipment - Trannys
The M/R drop-out cluster Saginaw Transmission, the ultimate light weight racing ... -M/R Saginaw Transmissions are completely torn down and inspected, ...
www.mrracingequipment.com/M&R%20Racing%20Equipme... - 36k - Similar pages
http://www.mrracingequipment.com/M&R...%20Trannys.htm
Manual transmission part, rebuild kits and overhaul kits Sag...
We offer a complete line of transmission parts, rebuild and overhaul kits to help you with manual transmission problems Saginaw 3 and 4 Speed cars and ...
www.drivetrain.com/saginaw3_4sp.html - 31k - Similar pages
http://www.drivetrain.com/saginaw3_4sp.html
Automotive General Motors Saginaw 4 speed Transmis...
Saginaw 4 Speed Manual Transmission Parts Illustrations ... Transmission model Saginaw 4 speed unit is shown in the following illustration: ...
www.drivetrain.com/transill_saginaw4sp.ht... - 15k - Similar pages
[URL=http://www.drivetrain.com/transill_saginaw4sp.html]http://www.dri
cool.... thanks for all the info. i looked at my trans i have and see that it has a single groove on the input shaft. which measn that it has these gear ratio's
1st 2nd 3rd 4th
1 groove
what would be a good ring gear to use. right now, i have 3.08's in the origonal ss differential. i am hoping to use the car for street/strip, not a daily driver, but i dont want something thats just going to burn through gas. hense wanting to maybe setup with a MAF TPI system. but, it still sems that a carb setup would be cheaper. so many things i want to do, and never enough money.
1st 2nd 3rd 4th
1 groove
2.54
1.80
1.44
1.00
