Replacing Blower Motor Resistor on 04 Monte
Hey All,
I wanted to know is this easy to do? The shop says I need a new Blower Motor Resistor/Heat Resistor and I would like to do it myself and save some money.
Thanks
Thanks
Hi Darious,
Check out the below links to see if they help...Good Luck
Im going to replace the blower motor resistor tommorow! - Grand ...
5 posts - 4 authors - Last post: Apr 30, 2008
#59369 - 04/29/08 11:11 PM Im going to replace the blower motor resistor ... I found some instructions on clubgp on how to change the blower motor resistor. ... Other toys: 72 Chevelle (owned since 1988), 04 Monte SS, ...
www.grandprix.net › ... › Older Models › 1997-2003 Grand Prix - Cached
Get more discussion results
Where is the blower motor resistor? - Topix
20 posts - 9 authors - Last post: Jul 7, 2007
before you replace the motor i would reccomend replacing the resistor ... I have a 2004 monte carlo. The blower comes on when it gets ready. ...
www.topix.com/forum/autos/buick/.../p2 - Cached - Similar
How to change out the front Blower Motor? - Chevrolet Forum ...
4 posts - 1 author - Last post: Apr 24, 2008
This gives you enough info to test it, see below to replace it. // There are two Blower Motor Resistors, the main resistor is located under ...
chevroletforum.com/.../how-change-out-front-blower-motor-15345/ - Cached - Block all chevroletforum.com results
Not helpful? You can block chevroletforum.com results when you're signed in to search. chevroletforum.com
YouTube - 02 Chevy Impala Blower Motor Resistor
Feb 15, 2010 ... Blower fan only works at high speed, replace the blower motor resistor. ... I have a 2004 Monte Carlo LS and the AC suddenly stopped blowing ...
www.youtube.com/watch?v=6-iBxXUWogY - Cached - Similar
Monte Carlo SS FAQ - Electrical
Monte Carlo SS Electrical FAQ Updated August 14th, 2004 ... Replace if necessary. Blower Motor. Inspect and clean the purple wire contact that goes ... The resistor assembly is secured with two screws on the top of the blower housing. ...
www.montecarloss.com/SS_FAQ_9.html - Cached - Similar
Huckster
08-14-2013 11:39 AM
Darius Lovehall
08-01-2011 04:52 PM
