Monte Carlo wont take any gas
I have a 2000 Monte Carlo and the gas hand was on a quarter of a tank. I drove further and the gas light came on so I pulled over and proceeded to pump gas in; however, the car let me put only $0.48 in and pushed the gas back out like it was full. What is going on?????
Not sure what your problem could be, but making 4 threads on the subject doesnt get your question answered any faster.
Sounds like it could be an evap problem. The evap system vents vapors and pressure from your fuel system. Your evap system may have a clog in it somewhere. The charcoal canisters are known to go bad and send little pieces through the evap vacuum lines. Also, make sure your filler neck doesnt have something obstructing it.
Thanks just at my wits end. just have too many dependant upon this one car. I relieved the fuel pressure on the fuel pressure valve and released some pressure in the gas tank and that let gas go in but the car did it again not long after i got in a gallon or so.
I think the evap system and the cap itself are the only vents the fuel tank has, but with the cap off, it should vent air to allow fuel to enter. Makes me wonder if either the filler is clogged or whatever vents the tank while you fill it is clogged.
schoentges16
02-27-2021 06:43 AM
BrandonStebing
07-25-2014 11:03 AM
blonco
03-31-2012 02:16 PM
nlange
11-08-2009 09:44 PM
