6th Gen ('00-'05): losing water?
losing water?
Hey guys! question: my '03 monte 3.8 is losing water, I have replaced the water pump (year and 1/2), had radiator fixed, 1 year, replaced elbows but not with the aluminum ones, new hoses etc., I am losing a lot of water from radiator without obvious leak? now just this past week I am hearing gurgling noises when I first crank up the car? yes I have not blead the system everytime I added water to rad so I get that but that does not explain the loss of water?? Is this upper/lower manifold leak and how do I know for sure?? thanks as always people!!... Claydoh
Running straight water can allow a slight leak to go undetected.
Trace water can be simply drawn through the EVAP System as a vapor if it gets converted to steam and gets vented along with Crankcase fumes.
Pull the PCV Valve and look for anything slime-related.
Not sure, ... but I think AutoZone has a Cooling System Pressure Tester you can borrow for free.
I checked O'Reilly and it looks like they have the tool; I'd imagine autozone has it tool.
Yeah that gurgling is air in the system and you hear the coolant/water in the heatercore. A lot of placed for a leak, but you can put some dye in and pressure the system as Rick is indicating. The only way to be sure is to start testing.
If "a good deal" of coolant is leaking internally, ... you will find evidence:
1) Checking your Oil for obvious contamination.
The Oil will become discolored and take-on a milky-looking appearance.
There will be a slime-like coating the Dip Stick and Tube.
2) You will likely find some gunky-slime buildup on the Oil Fill Cap and immediate area surrounding the Oil Filler Cap's inlet on the Valve Cover.
3) Similar evidence on the PCV Valve.
Thanks for the replies guys! I appreciate it!! after much further investigation, I have determined that the culprit of me losing water is again those pesky plastic cooling elbows which I replaced maybe two years ago!! once engine is hot I can see it seeoing out of the one that is visible. I checked the oil and rad for slime/milkyness etc that was suggested and found none? whew!! I am replacing with the aluminum elbows this weekend and hopefully that will fix her up!! again thank you for the help, Claydoh
