KR and choke?
KR and choke?
so i recently had to change 2 coils picked up some a set used from a junk yard.
it was going thru some bad shifting, misfires and hesitation not to mention my kr meter shoots upto 12 sometimes.
i changed the 2 coild that need to go and now have kr issues. after 3rd gear around 3-4k rpm i hear some kind of sparking or knocking and even if my foot is still on the pedal the car feels like its off for a second
i have the zzp super charge kit installed never had any kr issues till now.
what im wondering if its still from the coils or not, what i find unusal is when im on the highway, and try to go faster the engine feels like it stops for a sec kr meter shoots up i hear a lil knocking or sparking like when u unplug a wire from the coil.
i run 93 octane, engine feels weird still like loss of power and sluggish
thanks
thanks
You need to get off the throttle when you see that kind of kr! Kr will turn your engine into a ticking time bomb very quickly. I suggest doing a compression and a leak down test on the engine to make sure the engine is still ok and you haven't chipped a piston etc. If the engine is good you need to data log to figure out what is happening to cause the kr.
I would change the other coil and change plugs and wires. I don't think it's a ignition issue but doesn't hurt to do a tune up. I'm thinking more along the lines of a fuel issue though imo
Yea changing the coils got rid of my misfires, I'll take off the 3 fron plugs and check em out, I just tuned it up like 11 months ago with the install of the supercharged kit tho. I no i do have a fuel sender problem gauge goes from f to e every ten seconds , Also mechanic told me of a fuel pressure issue causing it to take long to start. And yes i did the fpr wasted 60$ :@ I dno i guess I'll check on the plugs in the am see what condition there in. If not I'm gna have to dish out for this ridiculous fuel pump job.
It sux i have to drive real easy on highways going to and from work
Wat y'all think?
Wat y'all think?
Wat y'all think?
Wat y'all think?
And fuel pumps are easy to do on later model W bodys... There's an access hatch in the trunk. Make sure you look at your wires on the sending unit also.
That being said, it never hurts to have a spare MAF laying around.
Kracktheskye
03-23-2011 04:45 PM
loudNproudSS
04-25-2008 10:27 AM
