i can hear gas sloshing around in the tank. is this bad?
Old 08-23-2012, 06:15 PM
usually when you hear it. it means that your sound deading material is waring out or the fuel is really low than what the gas guage is reading. other than that i would check out every thing as in check the bands of the tand as well as all of the tubes. i had to replace my filler neck on my mustang because i was hearing the same thing. i would check that as well. to see if there is no rust marks or any thing out of place or out of the normal collor.
Old 04-18-2018, 04:46 PM
Default Easy Fix
Most likely there is water trapped in one of your doors from the rain. Simply check each door and shake it to see which door has water lodged in it. Then go to the bottom of the door where the rubber seal is in simply pull it away. There is a drain that is probably blocked from the seal.
Motorhead
04-25-2018 08:08 AM
Deeana
05-22-2017 05:01 PM
prodigynius
09-04-2009 01:56 PM
zk6216
02-27-2008 08:14 AM
shmedley
07-01-2007 08:30 AM
Quick Reply: i can hear gas sloshing around in the tank. is this bad?
