How to get the Best MPG from your Monte Carlo : )
Old 05-26-2008, 05:50 AM
Default How to get the Best MPG from your Monte Carlo : )
Good, Better, Best: How to Improve Gas Mileage
[align=center]Whether you are shopping for a new car or just trying to maintain the one you have, you can take some steps to get the best mileage out of your gas purchases. The Federal Trade Commission (FTC), the nation’s consumer protection agency, offers these tips to use fuel efficiently: [/align]
On the Road: Drive More Efficiently
[ul][*][align=center]Stay within posted speed limits. Gas mileage decreases rapidly at speeds above 60 miles per hour. [/align][*][align=center]Stop aggressive driving. You can improve your gas mileage up to five percent around town if you avoid “jackrabbit” starts and stops by anticipating traffic conditions and driving gently. [/align][*][align=center]Avoid unnecessary idling. It wastes fuel, costs you money, and pollutes the air. Turn off the engine if you anticipate a wait. [/align][*][align=center]Combine errands. Several short trips taken from a cold start can use twice as much fuel as one trip covering the same distance when the engine is warm. [/align][*][align=center]Use overdrive gears and cruise control when appropriate. They improve the fuel economy of your car when you’re driving on a highway. [/align][*][align=center]Remove excess weight from the trunk. An extra 100 pounds in the trunk can reduce a typical car’s fuel economy by up to two percent. [/align][*][align=center]Avoid packing items on top of your car. A loaded roof rack or carrier creates wind resistance and can decrease fuel economy by five percent. [/align][/ul]
At the Garage: Maintain Your Car
[ul][*][align=center]Keep your engine tuned. Tuning your engine according to your owner’s manual can increase gas mileage by an average of four percent. Increases vary depending on a car’s condition. [/align][*][align=center]Keep your tires properly inflated and aligned. It can increase gas mileage up to three percent. [/align][*][align=center]Change your oil. According to the U.S. Department of Energy (DOE) and Environmental Protection Agency (EPA), you can improve your gas mileage by using the manufacturer’s recommended grade of motor oil. Motor oil that says “Energy Conserving” on the performance symbol of the American Petroleum Institute contains friction-reducing additives that can improve fuel economy. [/align][*][align=center]Check and replace air filters regularly. Replacing clogged filters can increase gas mileage up to ten percent. [/align][/ul]
At the Pump: Use the Octane Level You Need
[ul][*][align=center]Your owner’s manual recommends the most effective octane level for your car. For most cars, the recommended gasoline is regular octane. In most cases, using a higher octane gas than the manufacturer recommends offers no benefit. Unless your engine is knocking, buying higher octane gasoline is a waste of money. [/align][/ul]
In Advertising: Check Out Claims About “Gas-Saving” Gadgets
[ul][*][align=center]Be skeptical of claims for devices that will “boost your mileage by an extra 6 miles per gallon,” “improve your fuel economy up to 26 percent,” or the like. EPA has tested over 100 supposed gas-saving devices — including mixture “enhancers” and fuel line magnets — and found that very few provide any fuel economy benefits. The devices that work provide only marginal improvements. Some “gas-saving” devices may damage a car’s engine or increase exhaust emissions. For more information and a full list of tested products, check www.epa.gov/otaq/consumer.htm. [/align][/ul]
In the Showroom: Consider the Alternatives
[ul][*]
Old 05-26-2008, 05:56 AM
Default RE: How to get the Best MPG from your Monte Carlo : )
Additional Links below
... you are probably getting the best gas mileage your car can deliver. ... MotorWeek video shows how driving style can affect MPG and offers tips on how to ...
www.fueleconomy.gov/FEG/drive.shtml - 11k -
[align=center]Best gas mileage [/align]Okay, stick around and find out how to get the best gas mileage before driving to the end of the driveway. best gas mpg. First, one of the most important ...
www.energyrefuge.com/archives/best-gas-mileage.h... - 11k - Similar pages
http://www.energyrefuge.com/archives...as-mileage.htm
[align=center]Which Cars Get Best Gas Mileage? - The Green Pages News Stor... [/align]The Environmental Protection Agency rates the cars with the best gas mileage. Thursday, May 22, 2008.
www.kptv.com/green-pages/16337835/detail.html - 50k -
Old 05-26-2008, 08:02 AM
Cowboy6622's Avatar
but a 2x4 under your accelerator.... works better than anything i know
Old 05-26-2008, 09:37 AM
run some sea-foam in the tank about once every other month.... and if going on a long trip get three cans. put one in the week before you leave.. one in when you fill up.. and one on the way home... I live right outside Richmond Va and went to hatteras last labor day and did this and drove from here to hatteras and all around the outer banks upon topping off at the border station at the NC/VA line I put in 10 gallons and had gone 456 miles. with using sea-foam and chevron 87 octane and amsoil synthetic oil and keeping car clean and a good coat of wax I avg 34-36 mpg on hwy and about 29-31 in the city. even doing the three can trick going to visit family in sw VA through the mountains I avg 37-38mpg pulling up the hills. I also have the Michelin Energy MXV4's on her with perssure set at 34. hope this may help someone out there with the price of gas now a days
Old 05-26-2008, 09:38 AM
sorry forgot to mention my ride is a 03 ls with the 3.4 and 63,000 miles w/no motor mods, just flowmaster exhaust (resonator delete coming soon)
RedSS
12-13-2011 06:26 PM
76'Monte-carlo
07-30-2011 01:33 PM
08-13-2009 12:08 AM
05-16-2009 01:06 AM
05-01-2009 07:04 PM
Quick Reply: How to get the Best MPG from your Monte Carlo : )
