Welcome to the Monte Carlo Forum - Monte Carlo Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Like the title states, I think I'm having a problem with my gas gauge. It It will show one reading, and then out of nowhere drop a 1/8th of a tank, stay there for a while, and then go back up to some other reading. I've read around here that the motors on our different gauges can go out, but it still works so it isn't that, is it? Could it possibly just need to be re-calibrated or something? Any input would be greatly appreciated.
Thanks!
-Sam
__________________
2001 Monte Carlo SS w/ CAI, ZZP Downpipe, Kenwood sound system and much more.
Hi `Sam,
Have you had the fuel pump replaced? If you had, or not, you might want to check all your connections to the pump, make sure the positive lead to tank is secure and also you got a good ground on the tank too. Sometimes when a pump is replaced if not installed right the float in the tank won't work right or is hung up, and thats why it won't register right amount of gas on the gage.
Sometimes it's just a bad fuel tank sending unit in your tank.
How many miles are on your Monte ?
Good Luck `Sam
Member's, your turn 2 help `Sam
on his prob...post it `ok
our fuel tanks are known for their bad sensors. BowtieTech has a very nice write-up in another thread on how to replace the sensor through the trunk, instead of having to rip the whole tank out. Hopefully you can find that thread.
Also, a thing to note is never to fill your gas tank past it's point of being full. I know some people will pay for gas, and when it stops at say... $14.23 they will go all the way to $15.00 to "even it out"
That's bad for the fuel filter and other various parts. The car says enough for a reason haha
__________________
2000 Monte Carlo SS | 2013 Camaro 1LS | 1968 Camaro SS
And I usually don't fill her up past half, and when I do fill her up don't top it off. Buuuuttt..... I bought it used with 68,000 miles on it, and for all I know the previous owner could've.
It now has about 78,000 miles on it.
Anywho, I'll check out the sensor in the next few days, as well as the connections to the fuel pump.
Thanks guys!
__________________
