7th Gen. Filling Gas
Old 03-07-2012, 09:17 AM
wiseheak's Avatar
Default 7th Gen. Filling Gas
Ok, so it seems like every couple times when I go to fill up at different gas stations, the pump keeps stopping like 5 seconds into trying to fill up. It will continue to do that until I move the handle around. It's almost like there's a certain position the nozzle needs to be in to actually get it to fill without stopping every few seconds. Does anyone else have this problem or is it just me?
Old 03-07-2012, 10:19 AM
Typically this means that the vent in your car is clogged.
That's how cars know they are full. The vent stops working because fuel is there.
Old 03-07-2012, 10:37 AM
Mine does to to, just never had a chance to check the vent tube, but if u put it in & only go bout half on pulling the handle up itll keep goin
Old 03-07-2012, 11:37 AM
xxtheshockerxx's Avatar
RED DEVIL
had the same problem on my 03..never really tried to fix it though just traded it in like that
Old 03-07-2012, 11:42 AM
Taz is offline
I've had that a couple times also. Usually with the same pump. Other pumps didn't do it. I was assuming it was the pump's fault. But I'll have to remember the vent next time.
Old 03-07-2012, 11:50 AM
I think it is the way different pumps are made. Could be ta car issue to but try other gas stations.
Old 03-07-2012, 12:17 PM
Mine does the same thing, but only on certain pumps
Old 03-07-2012, 12:56 PM
When it changes with the pump, I would suspect the pump and not your car.
But if you go to multiple stations and it keeps happening, I would blame your car.
Old 03-07-2012, 01:52 PM
Mine does it sometimes too. I just put the pump in kinda sideways and it works fine. Where is the vent that could be clogged.
Old 03-07-2012, 02:23 PM
wiseheak's Avatar
Yeah I figured it would be something wrong with my car because it's happened at a few different stations. I just wasn't sure if it was a problem with the 7th gen's being real sensitive or something.
If it is a case of a clogged vent, is there a way to get to it?
Quick Reply: 7th Gen. Filling Gas
