2006 Monte Carlo SS wont start after installing battery
My battery died in my SS last week. I had a buddy give me a jump but battery would not hold charge. Took battery to O Reily discovered battery is totally dead. I installed a new batter but now my car wont start at all. All electrical seemed to be working relative to radio, fan,lights and etc..Please help.
When you try to start the car:
- Do the lights and needles on the dash behave normally?
- Does the starter make a ticking/tapping noise, no noise or the normal "cranking" noise?
I'm wondering if the car has activated the "theft lock" system (just a random guess). But knowing a little more may help.
Just for peace of mind, look on the battery and make sure the CCA is a number greater than 650
Some autoparts places might not care. This time of the year (depeding on your location) the CCA are a big factor in whether or not the car will start. Other than that, I would recommend just double-checking all of your connections.
It also couldn't hurt to get the starter tested, but I know they aren't the easiest to get to.
Check the ground wire connection where it contacts the body/frame. Check the positive cable (and other) wires at the starter solenoid to insure they are clean and tight. As Jason also mentioned, it may be the anti-theft system is active.
schoentges16
02-27-2021 06:43 AM
bigdomvegas
10-21-2017 07:54 PM
6th Gen ('00-'05): monte carlo won't start immediately after installing new battery
bonzolead
02-26-2015 10:15 PM
BrandonStebing
07-25-2014 11:03 AM
