6th Gen ('00-'05): 05 monte ss, need advice
I have misfires on all but cylinder #1, I have new plugs, I swapped out the coils, had the injectors checked and now I'm lost. Also the fuel pressure stays steady at 44psi off and while on and pressing the gas it goes up a few then comes back down. Someone I know with a snap on scanner tester showed no other codes but he tested it for misfires and we saw 2 through 6 all intermittently misfiring...What could it be? Is the battery a possibility? It's also running lean p0171
Thanks
Thanks
