Guide: Replace Gear Shift Knob
Replace Gear Shift ****
I finally did it. Here is how.
I replaced the stock shifter **** with an Autotecnica APA 100-510 (Carbon fiber like with leather)
Tools
* 2 pairs of needle nose plyers (one is ok if you have a pair of rounded nose plyers see below)
* 1 pair of rounded tipped need nose plyers (if you do not have two pair of needle nose plyers)
* an extra set of hands is helpful but not required
Steps
* Pull down the leather wrapping that is directly below the shifter. This wrapper is called the bottie.
* The **** is attached to the shaft by a 'U' clip the 'bottom' part of the 'U' clip can be seen slight sticking out the front (toward the dash) of the ****
In the rear of the ****, you will see two small slots, this is 'top' of the 'U'. With a pair of need nose plyers squize the sides and press in.
* The 'top' part of the 'U' should start to pop out. With an other pair of needle nose plyers or round tipped needle nose plyers, pull on the 'U', this is where the other set of hands can come in to play. If needed to get more grip, push the 'top' part of the 'U' in a little more.
* When the 'U' is out all the way, pull up on the ****. That is it. I would recommend that you put the clip back in the **** where it came from, so you do not lose it.
Tools
Steps
RE: Replace Gear Shift ****
oooo oooo oooo me two want to see pic's too !!!!!!
i have thought of doing somethin like this once. then i looked at it and thought it might not be as much fun LOL
Also have see where folks have shortend the stock one so that it was not in the way all the time
I am rather unclear on the Gen? and where did u get the shifter?
Yes lets c some pics of it installed please
and the rain if it will melt the snow and/or get the salt off the road send it here lol. I prefur rain over snow anyday
Hi Jonny.
Ralph retired from the forum years ago.
I'm pretty sure he was referring to the 6th gens. But I think it may be the same, if not similar, for the 5th and 7th gens too.
Why did I bump the thread? I'm going through the threads in this section and placing them where they properly belong. Plus many How To's were damaged by our server problem in 2008. I'm attempting to repair them or delete them if they can't be salvaged.
