Guide: Oil change (6th gen)
Old 05-25-2010, 03:26 PM
If your engine is in good mechanical condition with no leaks 10 k miles is not impossible with above synthetic oils. The change can be extended by oil analysis. I tested my wife's 99 astro 4.3 v6 right at 10 k several times now I just let the change run the full year, the analysis always came back good for continued use. At 148 k she is running good as when we purchased 11 years ago with 12 k miles.
Old 05-26-2010, 02:13 PM
I would actually buy 6 quarts because I change my oil the same way, about half a quart to fill up the new oil filter before you put it on the car. I start my car and check the oil level and if it's a little low, a splash of oil from that 6th quart does the trick.
Thanks for the tip. But just in general, I should only need to put 4 qt.s in the engine right? I have the LS, didn't know if it would be a different quantity for the LS vs. SS
Old 08-14-2010, 04:09 PM
Can someone make a "How to" video on how to change the oil on a monte carlo. I am a novice at car repair.
Old 12-06-2010, 05:35 PM
Thanks for the right up i'm thinking about doing a Moblie 1 synthetic .
Old 03-10-2011, 06:40 AM
I'm not a GM certified tech but I've been around a lot of cars and I've never heard of putting a half-quart of oil into the filter but I gotta admit, I can't say that it sounds like a bad idea. I'm takin my 04 Dale Jr. on a cross country trip so I'll be changin the oil before I leave and I'm gonna do that. Thanks for the new idea!
Old 03-10-2011, 12:34 PM
Good write up I've never actually read how to do it, glad to see i'm doing it right.LOL I always poke a hole in the old oil filter and let it drain before removing it. Then you dont have to worry about spilling oil everywhere.
Old 03-10-2011, 02:01 PM
I take my passenger front tire off on my 3800 engine to reach the oil filter MUCH easier.
Old 03-10-2011, 05:40 PM
I just move cars around and use lift in garage...
Old 03-10-2011, 06:13 PM
Aren't you special :P
Old 03-10-2011, 06:14 PM
Damn zjerry love ur garage !!!!!!
ChibiBlackSheep
30
08-19-2022 07:59 PM
ChibiBlackSheep
31
09-03-2015 01:49 AM
mstrmysterious63
09-25-2012 03:04 PM
Tzarm
08-20-2012 09:20 AM
70monte1
25
01-19-2010 09:04 PM
Quick Reply: Guide: Oil change (6th gen)
