Guide: 5th,6th,7th gen console shifter knob replacement
5th,6th,7th gen console shifter **** replacement
***Pics are from me replacing mine on my intrigue thats why it looks funny but will be the same in just about any auto car with the shifter on the console
Step 1 get your favorite small flathead screwdriver
(I used a 1/8th in Craftsman)
STEP 2 with the car off put the parking brake on or block your tire so it wont roll
Step 3 push on your brake, turn the key to the acc or on position, then put your car in 1st gear, once in first locate the clip that holds your shifter in place
Step 4 insert your scredriver towards the top of the slot, pull handel up, you should feel some resistance and will start to see the clip
Step 5 pull up on your ****
Step 6 get your new **** and slid it on and replace the clip, i pushed it in as far as i could with my finger then used my screw driver to finish it up
(like me you may need to get the shifter boot back on)
Sad thing is i liked this shifter **** enought i put the broken on in my saturn!
ChibiBlackSheep
60
12-09-2012 07:13 AM
Repair Guide: 5th, 6th, 7th Gen Rear Strut Replacement
Budsjlm
FWD Tech Guides '95-'07
11-26-2012 08:00 AM
MJClemm
02-04-2011 05:12 AM
