Turbochargers Vs. Superchargers ?
#41
there is a way to run both. but the boost on both must be low and I would not be surprised to have the engine to have rediculus amount of blow off valves. I seen two so far that has both having at least two blow off valves that I seen. I have noticed one thing superchargers are good for top end and turbos are good for bottom end. I think I got those two backwards. having both seems like a balance on both ends of the spectrum. but it is a lot of work but a good pay out though. but on a fwd the room is a little tight but would be interesting to do. kind of wish that the 3.5 and the 3.9 has the supercharger for it. because I would love to have that option the supercharger. but the turbo is a good option for me but a bit pricy for fab
If you want a big power setup, a turbo is the way to go. A properly setup modern turbo system can come on plenty strong with brake boosting and a looser converter. Certainly more than street tires could hold anyways. If that's not enough, you could always add a 100 shot or something to get you out of the hole and have it phase out once boost comes online. That way you get your instant power without all the supercharger BS.
#42
What bumpin said is exactly right. I personally know of a twin charged 3800 and it performed very well but never made big power.
The little m90 blower for the 3800 runs out of steam around the 400-450whp range where a turbo the sky is the limit basically. Also, people complain about lag but I'm soon to have that issue fixed as well with my anyilag setup
14
10-07-2013 12:02 AM
05-15-2012 05:28 PM
MC3point5WAX
05-23-2011 06:49 AM
01, 05, 35, bigger, car, carlo, chargers, cons, exhaust, lag, monte, pros, put, supercharger, superchargers, supercharging, turbo, turbocharger, types
