Turbo monte current build has been demodded.
#41
You also have a fine turbo Greg. I will be having my hot side heat coated and cold side powdercoated as well but haven't decided on a powdercoat color. Heat coating will be black. Charge pipes, TB, intake manifold will also be powdercoated but idk a color there yet either... Ideas?
#42
*Update*
Just got my precision 46mm wastegates. I am running two of these, one on each exhaust manifold then to the divided turbo housing. These will be open dumped using "screamer pipes"
#43
I'm probably going to do the Holley Water / Meth system now as my Cooling Mist setup is about 8 years old. My control module has failed so I think the systems lines, nozzles, pump has seen its better days. The Holley 1000cc W/M solenoid just arrived yesterday. Need to do the Holley pump and small related parts now. Your Cooling Mist W/M system is relatively new isn't it. You probably have all the new technology that they have available so your more than likely good to go. They don't even offer my style controller any longer. Matt figures lest just optimize everything to one sources products and it should tune easier.
Well good luck brother, make sure you post more pics of your goodies as you get them. Those Precision Waste gates, duals none the less, a set up one per manifold will be sic guy. The benefit is your engine is able to release manifold pressures less obstructed? Therefore your engine will operate more efficiently? You are going to need the M/T tires...
#44
Thanks bud, estimated completion date is sometime in the spring and for sure before June. The cts-v sits in the garage during winter. It's another fun toy and is not daily driven.
I do run the cooling mist kit but mine is only about 3yrs old. We contemplated upgrading it but we are trying to make it work before dumping more money into it.
I do not know of any other 3800 running two wastegates, I am doing it so I can spool easier with the divided housing while still keeping a big AR for top end. Also another reason to do this is it gives up way better boost control.
I will keep this thread updated as the project progresses
#47
Well Bumpbin you mention the speed controller, have Aeromotives latest model installed (Black body) for about the last 2 years and the Aeromotive Red speed controller for about 5 years before that one. This time we went with 80lb injectors and a lower the pumps speed when not under boost. You may be right about adding larger lines from the tank. We are stripping out all the lines under the car up to the fuel cooler, all new teflon, stainless braided ones. Mat put a CTS-V pump on a Camaro with similar problems and it went away. If it fails then will have to copy Johns and yours closely.
The next best step is a hobbs switch, especially with dual 255s. Lots of people run a single 255 with no overheating issues, so that's a proven setup. Then the hobbs can just bring on the 2nd pump whenever you get into boost.
#48
#50
Not too much of a update yet. However there is a little news lol.
We decided not to use the f body intake. We are still going to use a l26 uim but make it passenger side inlet. I bought another l26 uim and it should arrive at the shop today actually. All of the piping is in as well. Once the uim gets there they will begin fitting it to make it passenger side inlet. Once it's fitted they will make the new cross over and mount turbo, then fab up downpipe, charge pipes, etc. After that wiring will start. It's gonna be a long process by the sounds of this all lol. I sure hope they have it done in a couple months. Hate to miss out on most of the summer do to car being at the shop.
As more progresses and I get pics I will be sure to share here and keep everyone updated
