Tuning...??
Hi `David,
What type of tune do you want for your Monte Carlo ?
What Mod's do you have now ?
From Mr Google:
The Speed Shop < Click
EFILive GM Tuning 98 and newer
From Mr Google:
4881 highway 55 south
Jackson, MS 39212
(601) 372-7889
(601) 372-7889
- Naturally Aspirated - $500
- Power Adder - From $550 up
Call For Custom Quotes
Performance parts sales and installation
Speed Productions < Click
www.speedproductions.net/
... custom tuning solutions, and fabricating company located in central MS. ... Carincludes a VMP TVS, Circle D Specialties converter, BMR Suspension, and .
https://youtu.be/qfAON8KN33U
Agree, what are you looking for in a tune? If it's basic adjustments then just buy a mail order tune and call it a day. If you did major modifications then best to have it dyno tuned, best bet for this is search reputable gm tuners in your area or travel to a reputable 3800 tuner.
Lol. Speed shop. Im gonna stick to if I don't have anything nice to say, etc., etc...to be fair I don't personally know them, and I'm sure they are good people.
A dyno tune. I have hpt. And not a $1500 for 3 pull dyno. I have 3, 3800's so mod list is too much to list. Only two ready right now. The monte Carlo is a long ways from being ready. The other two, heads(1), cam, fuel pump, 80# injectors(1),42#(1), intercooler(1), 3.4, 2.8.......; ) intakes, and a bunch of suspension work. Only one has new struts right now, bmr rear set up on one, only lateral arms on the other, adco front bars, and everything else isn't really pertinent to list out
Will may be able to help you, he's not located near you but if you tell him everything done he can probably do a great tune for you and mail you the pcm. He did mine in my car and I can't say enough good things about his work. Here's a link to his website
:: Overkill Motorsports ::
The cost isn't in buying tuning hardware/software, you're paying for their time (could be a few hours to half the day), dyno rental time, and their expertise. Taking your car to a place like zzp for a full custom tune isn't going to be any cheaper. Honestly, if you have the money for 3 fully built 3800s, $500 to get each one tuned in is just a drop in the bucket.
The way I see it, you've only got a few decent options:
-Learn how to use your HPT and tune them yourself. This is by far the most cost effective, but could also be the most time consuming / risky depending on your experience level.
-Find a local speed shop that does GM tuning. As mentioned above, this will easily be $500/car, but this will probably get you the most out of each setup. Just keep in mind, they're likely not 3800 experts, so they aren't going to be able to maximize the car quite as well.
-Get a mail order tune from a known 3800 vendor. This will be cheaper than the above, and will likely be te most reliable option, but it won't really get the car dialed in, so you'll leave a lot on the table as far as power. They have to tune conservatively for the worst case of that setup.
I guess there is technically another option. It would give the most reliable tune and the most power, but it is also by far the most expensive- that would be getting an actual 3800 expert to tune them. The vast majority of the big 3800 shops are in the midwest, so youd either have to have a semi take all your cars up there or fly one of them out to you for a weekend.
Well for one, maybe I only have the money to mod the three vehicles I own because of how I manage money. I didn't notice that theory in your breakdown. So, the wise decision I get out of your suggestion is, since I got the money just throw it around selflessly, because I got it like that? Cmon, now man. You're obviously intelligent. 4 years ago, I was homeless. Lost it all for dope. So I'll admit I can be a cheapskate with money, because a part of that having nothing mentality still sticks with me. The $500 per car thing you ran with isn't the correct option either. That's $1500 a vehicle. 3 pulls max to change parts out while on the dyno. My experience (and this was 5 years ago and maybe things changed) when I lived in CA was $500 per vehicle/dyno tune. My though process on that was...A) that was a more common of a higher hp vehicle (srt v10 ram) B.) MS cost of living is way cheaper than CA. I would assume pricing would be less here for a dyno tune than it was in CA. But, maybe not, it was a while back. You're right though. Learning to use hpt is something I try and do every day. There's always room for improvement and I by no means can claim to be anything more than a rookie when it comes to using it. Im pretty sure I won't learn it overnight or in the next month even if I quit my jobs. I would like to get at least one of my cars done sooner than that, which I why I'm here. As far as the speed shop, I'm not going to slander anyone put anyone's business out there. All I can say about that is the ad is misleading and more importantly it's an environment I choose to stay away from so history doesn't repeat itself. I appreciate you taking the time to break that down, and do value your input. I'm not upset or trying to be some keyboard dick. (I couldn't back it up anyway, lol) thanks again bud. If I don't puss out, hopefully in the next year I'll be in the twin turbo group myself. That's a mighty big IF, though
I was just trying to lay out your possible options. Realistically, since you're nowhere near the big 3800 shops, you're cheapest option is probably to find a big LS tuner and have them do it. You're still going to be about $500 / vehicle though. One option is to sell your hpt, that alone would almost pay to tune one of he vehicles.
I also don't understand what you mean about changing parts on the dyno. You should have all of your parts installed before you take it up there. If you can't change injector values with your hpt, then just drive up on stock injectors and swap them in the parking lot.
Also, it doesn't really matter the hp of the vehicle. A v10 isn't necessarily going to take longer to tune than an I4 or cost more (unless you're paying "exotic car tax" for something like a Ferrari). The amount of time put into it is about the same. What matters more is how different your car is from stock. Headers and an intake will take less to dial in than a car with that plus a cam, e85, bigger throttle body, etc. Honestly, your cars are on the more heavily modded end with heads/cam.
