transmission fluid change
So I jus changed the fluid in my 03 and I only droped the pan n changed the filter and fluid as recommended by all of you.I did not change the gasket thogh because I heard they are reuseable is that true or shud I have changed it also?
The OEM gasket is a pretty sturdy piece and if you cleaned it up and torqued the bolts properly it should be fine, I changed mine when I installed the shift kit and filter but I'm a firm believer of never reusing a gasket unless you have no choice, just my habit
Aaron
Aaron
7th Gen ('06-'07): Change transmission fluid for Montecarlo LT 2006
horrible555
05-07-2012 01:33 PM
dcnaser
03-25-2012 07:40 PM
