transmission fluid
Old 10-18-2009, 02:38 PM
I'm pretty sure that Dexron VI is full synthetic, use it, it's that much better
Old 10-19-2009, 12:54 PM
MAMONTE's Avatar
Dexron VI is not a FULL Synthetic from the factory. It is a Semi-Synthetic.
But you can buy FULL Synthetic formulas of it. I know Valvoline makes a Fully Synthetic, Amsoil does, and Red Line does...So far those are the only ATF's that meet Dexron VI spec that are FULL synthetic. (at least those are the only one's that i've found, let me know if anyone finds others)
Old 10-19-2009, 01:40 PM
2003supersport's Avatar
Photobucket
Monte Of The Month -- May 2009
Originally Posted by chibiblacksheep
I'm pretty sure he'll pass you
Im always up for a challenge
IMO, i love AMSoil. tranny and motor run it. I love it because its a full synthetic. A little more pricey, but you dont have to change it as often. motor oil i change every 5k, and the tranny now that i got it changed about a month ago, probably wont see another change until i swap the tranny for a built one. I've never seen my tranny temp go above 195 degrees, even when i drove to san jose and it was 100 degrees out.
Harleyldraper
08-04-2010 06:25 PM
Jack The Ripper
03-31-2010 01:46 AM
KINGSS
10-22-2009 06:56 PM
Frosty LS1
08-15-2009 06:43 PM
jaws2008
02-12-2009 11:21 AM
Quick Reply: transmission fluid
