transmission fluid
Old 10-15-2009, 01:24 AM
KINGSS's Avatar
Question transmission fluid
i want to change the fluid on my 03 ss as it has 86,500 miles and i have no idea if it has ever been changed.just wondering what is the best replacement fluid to use.thanks.
Old 10-15-2009, 02:35 AM
Dexron 3 is what the transmission came with, it's the GM recommended fluid. If you want to really keep your tranny healthy and spend a bit more money go with Dexron 6, it was produced after 2003, but will still work with your tranny. This is a half synthetic blend, overall just healthier fluid.
Old 10-15-2009, 03:51 AM
2003supersport's Avatar
Photobucket
Monte Of The Month -- May 2009
wow, finally have a member thats somewhat close to me. oakland eh? im on the other side of the bridge.
u want a good fluid, my recommendation is to use AMSoil tranny fluid. its not gonna be a power difference, but it does offer great benefits for long term use and durability.
Old 10-15-2009, 07:29 AM
for the economical choice, i would recommend Napa dexron 3 fluid. i've used it in many vehicles over the years with no problems and it doesn't break the bank. Valvoline dexron 3 is one i also recommend. it's even held up in my derby car trannies that aren't cooled (since i cut the cooling lines back to the tranny and loop them together) so it's taken lots of abuse. just don't go buy the cheapest stuff you can find on the rack.
Old 10-15-2009, 08:23 AM
I second the notion for Dexron 6. Stick with the GM brand of Transmission fluid. I wouldn't get into all the aftermarket stuff.
Your car will call for Dexron 3, but as was stated, that's simply just because 6 was not invented yet. But it is completely compatible and will run cooler.
Old 10-15-2009, 10:56 AM
can someone refresh my memory on what brand engine oil/tranny oil the GM dealerships use? i thought i heard valvoline once a long time ago but i'm not sure anymore. just curiousity on my part.
here at Cummins we use what they call "Cummins Blue" engine oil, when in fact it's actually made by Valvoline.
Old 10-15-2009, 02:08 PM
KINGSS's Avatar
Thanks everyone.sounds like ill go with the dexron 6.and 2003supersport maybe ill pass you up one day lol jk
Old 10-15-2009, 02:10 PM
I'm pretty sure he'll pass you
Old 10-15-2009, 06:55 PM
IMO! At 249WHP I think you're right.
Old 10-15-2009, 07:05 PM
MAMONTE's Avatar
I know i'm late on this post, but go with Dexron 6 for sure...none of the Dexron 3's on the market are actually licensed by GM anymore, so you really don't know how up to snuff the formula is.
GM Dexron 6 is made by Petro-Canada....
AcDelco Dexron 6 is made by Shell...
I use Valvoline Dexron 6 Full Synthetic.
Quick Reply: transmission fluid
