SS M90 Installation on 2003 Monte Carlo SS Thread
I could see that- talking peak power. What makes the biggest difference in regular driving though is that it's making more power now throughout the RPMs- the power band is significantly fatter and the mid-range and top-end is way better. The car always had decent "grunt" down-low- now it has better "grunt" and it continues to pull, whereas prior to the installation it would fall on it's face.
Once I get a half-decent exhaust on it and a cold air intake (my IATs are insane right now), I should be able to run a little more timing and pick up an honest 10-15 more HP over where it's at right now, too.
Is it possible to buy an Eaton blower from clubgp and have zzp or someone port it to the l36 ss m90 specifications? Would it be any cheaper than just buying the $960 blower that zzp offers already ported and modified for the install? What about the fuel logs? Does anyone ever sell those in good condition?
Yes, you can make a regular old M90 work with the SS M90 kit. You would need to run ZZP's MPS hub along with an SS M90 specific pulley. You will NOT need to port the blower- ZZP probably just does this to charge more (and to get you to buy their SS intercooler, which is conveniently matched to the ported blower).
You may need to grind some material from the lower mounting "legs" on the outside of the blower housing to clear the fuel injectors- no big deal.
You do need the SS M90 fuel logs as far as I know, since the injectors with the SS M90 kit are housed in the lower intake manifold and not the cylinder heads. These are pretty rare used, unfortunately.
Sorry for the late response- I never check this forum. Hit up ClubGP for better responses.
So I could just buy a regular m90 blower and put it on there? I thought ZZP ports the blower for some kind of special air flow.. but they just port it to fit the fuel logs on the outside?
The late response is okay. Atleast you did respond
they need to get on the ball and make something like this for the 3.9
It sounds like you're trying to save money on the project- have you thought about just doing a traditional top swap? It is more work, but you'd save a good bit of money too (especially with some of the dirt cheap setups going through clubgp lately).
The only thing I'm unhappy about is that they sent me the wrong PCM (mixed up mine with another order), and aren't going to ship the right one to me until tommorow- I asked them to ship it overnight, but we'll see if they actually do. I think it's the LEAST they could do, since the error was on their part.
I was first thinking about doing a full top swap. However, my parent don't want me taking me engine all apart because I haven't really done much cars before. I figure, I want more power, without having to take apart my engine. Then I found the SSM90 kit. It's perfect. 2-8 hours of work will get me more power and I don't have to swap the whole top half.
ZZP is trying to charge $960 for a ported blower, which I think is COMPLETELY ridiculous. So I've been searching around for a blower off of clubgp or somewhere to buy for cheap and just send in the blower for porting (which I'm not even sure is necessary anymore). I've seen some decent power come from the kit, so that's what I'm trying to go for.
I thought the porting was for KR since you are mating this to a high compression block.
If they have a hard time with that- how about buying a used turbo kit? You don't open up the engine at all really with one of those, and if you factor in that $1000 blower and $500 rails- I'd bet it would be the same price give or take a little.
