running hot???
running hot???
Hi. I am new here & semi new to my 95 Z34... I had the intake manifold gasket and thermostat replacedand since then my car has been running hot- it cools down at red lights but shoots up to HOT! when I drive the freeway... seems backwards... I have replaced all my fuses and relays and that helped for a day. When I took it back on the freeway it shot up to the red and has been riding the line between white & red and cooling down at stops... anybody else have this problem or know of it? Any suggestions would help. Please and Thank You!
RE: running hot???
I did make sure it was bled & just to be safe I had it done again... I am not sure if the sensor is plugged in or not but I think it is because I replaced the relays again & it worked for one drive and when I went to test it out again, it ran hot after 2 blocks! My guess is that something is causing the relays to blow...
