Over heating
Old 11-22-2011, 08:53 PM
Rick11's Avatar
Default Over heating
I have a 03 monte 3.8 l-36 I start the car it it runs fine after warm up it starts to knock as if there is no oil and when I went to check the oil level the dipstick was too hot to touch so I checked the temp guage and it reads normal why would this engine get hot like that after only running for 5 to 10 min is it possible that there is not enough anti freeze or air trapped in the cooling system.
Old 11-23-2011, 08:45 AM
Pop your engine cover off, open your thermostat bleeder valve and start the car. Get it to the point that coolant is flowing out of it and you'll know it's not air
When was the last time you flushed the coolant?
Old 11-23-2011, 10:28 AM
Blazed SS's Avatar
IT HERTZ
here is what it looks like
Old 11-23-2011, 10:31 AM
Rick11's Avatar
When I pulled the engine cover discovered that the plastic fuel line had melted after I repair this I will do a coolant flush I have never done a coolant flush since 2003.
Old 11-23-2011, 11:29 AM
Then there is a good chance that the Dexcool (which at a MINIMUM should be flushed every 5 years, I do it every 2) is very thick and nasty right now.
I would drain everything, and circulate water through your system, drain the water, and repeat with water a few times. Then fill back up with a 50/50
oneandonlydylawn
06-02-2013 02:15 PM
chamberz
07-15-2009 02:02 PM
connersdad19
05-29-2009 03:24 AM
sprfrk2005
05-20-2009 09:15 AM
bjar61
01-07-2009 04:48 PM
Quick Reply: Over heating
